Crankshaft Pulley Bolt
HI Guys, Please can anyone tell me is the Crankshaft Bolt a Left or Right Hand Thread need to undue as fitting a dry sump system etc.
Many Thanks.
Many Thanks.
Member
The main pulley?
Its a normal thread (right = tight left = loosen)
Im guessing you've triet to get it off and are now thinking its wrong handed?
Its a total bastard to get off. You need the Honda pulley removal tool to hold the pulley, then a breaker bar with a 19mm impact socket. I had to use loads of plus gas, then use a 4ft scaffold pole over the breaker bar.
Good luck!
PS - why would it have to come off for a dry sump?
MB
Good luck!
MB
