Couple of nut and bolt questions
Need a couple of s2000 bits for my f20c kit car and not sure where to buy from.
1; need alll the short bolts and nuts which connect diff to drive shafts
2;my s2000 engine mounting bolts stick a long way through my 4mm flat plate steel mounting plates meaning I need some spacers to cover the un-threaded part of the mounting bolts. Does the s2000 have spacers? or are they mounted through a very thick section steel? If so I need 4x spacers for this!
Any help would be great thanks
