coolant question
coolant question
the wee coolant container at the front right of the engine - what do you fill this up with exactly? - mine is at the "min" mark just now...
sorry for the daft question...
My advice would be:
As long as it never drops below the minimum level don't worry about it. If it ever does drop lower then get a dealer to check your coolant system for leaks because you have a problem if coolant is being lost. If you want to top up in an emergency to drive to the dealer, use de-ionised water (the wrong sort of anti-freeze may cause problems with corrosion or head gasket).
EDIT: Quote from GSi's link:
"Other antifreeze formulations include silicate-free for Japanese cars"
