coolant expansion tank
Old 07-27-2007, 01:32 AM
johnbuck's Avatar
Default coolant expansion tank
Sorry, this is a stupid question but I've done a search and checked my handbook but still can't clarify the answer.
Should the coolant level in the expansion/reserve tank be checked when the engine is hot or cold?
I had my coolant changed yesterday and on checking this am, the expansion tank is just about empty. The coolant is at the correct level in the radiator though.
Old 07-27-2007, 01:41 AM
Slickline's Avatar
I would reckon on checking it when cold, when the cooling system is hot it's under pressure and there is a risk of scalding yourself with steam/very hot water.
As for the drop in level it could simply be air in the system migrating up to the expansion tank and therefore causing a drop in fluid level.
HTH
Old 07-27-2007, 01:52 AM
johnbuck's Avatar
[QUOTE=Slickline,Jul 27 2007, 10:41 AM] I would reckon on checking it when cold, when the cooling system is hot it's under pressure and there is a risk of scalding yourself with steam/very hot water.
HTH
Old 07-27-2007, 03:42 AM
mikey k's Avatar
If you over fill it it should just dump the excess out.
Old 07-27-2007, 04:02 AM
euan's Avatar
Mines always checked when cold - never noticed it change when hot, but then I tend to avoid poking around when the engine's in that state.
rudyy
04-26-2020 02:13 PM
yorkies2k
11-15-2013 11:24 PM
tozerman
09-25-2013 07:15 AM
GDM S2K
02-10-2009 04:58 AM
ChefJ
08-21-2007 07:32 PM
Quick Reply: coolant expansion tank
