Compression number and sparks gap
Hi I am servicing my S this weekend and i want to confirm the recommended:
Sparks Gap
Cylinders compression number - this is to allow me to check if there are any leaks in the cylinders. For those who don't know this here is a link on how to do compression test: http://www.automedia.com/Engine_Compressio...ccr20050801cc/1 with pictures.
Thanks.
Sparks Gap
Thanks.
re -compression test details:
https://www.s2ki.com/forums/index.php?showtopic=434729
anyone got recommendations for spark gaps?
To add to that you can have a minimum of 135psi and max of 28 psi between them.
Depending on how you do it, battery etc you can have varying results but i doubt you will get 228psi per cylinder.
Also spark plugs, NGK look at the FAQ.
