clutch slave cylinder
Old 06-08-2008 | 08:55 AM
Bibbs's Avatar
Default clutch slave cylinder
well after 700 trouble free miles i thought i would take the s for the renault world series.
Bad idea. Floppy clutch pedal and a leak under the car. I thought it was the hose split but the man from the rac said it was the slave when he got under the car.
Well i have had to abandon the car at a garage local to silverstone.
Anyone know the cost of a replacement? I cant see the swap taking too long.
Old 06-08-2008 | 09:02 AM
RedUn's Avatar
30 quid seems to be stuck in my head Bibbs i'm sure it's around that.
Two minute job to do.
Old 06-08-2008 | 09:08 AM
Bibbs's Avatar
that is great news. I would diy it, but obviously i an at home and the car is 60 miles away.
That is not too expensive luckily. Cheers!
Old 06-08-2008 | 11:42 AM
chrisr111's Avatar
UK Moderator
A new clutch slave cylinder is around
Old 06-08-2008 | 11:49 AM
Bibbs's Avatar
Ouch .. damn it.
Oh well. If it needs changine though, I've little option.
Any other things I could do at the same time?
I'm going to get them to re-grease the bearing while the fork is out.
Old 06-12-2008 | 08:29 AM
Bibbs's Avatar
Defo this that's dead.
But Honda are out. Several local dealers are out.
6 weeks from Japan.
Old 06-12-2008 | 08:45 AM
mikey k's Avatar
Used one from breakers?
Old 06-12-2008 | 08:54 AM
veehexx's Avatar
i could be wrong - but im guessing it's just a seal that popped?
cant you get repair kits for slave cylinders; like you can with calipers?
Old 06-12-2008 | 08:55 AM
Shopman's Avatar
Elsewhere someone posted a link to Southbay Honda and they will deliver to UK.
Had a quick look and found this Link
Prices look good.
Old 06-12-2008 | 10:03 AM
Bibbs's Avatar
mikey - Thought about that, but would prefer new.
veehexx - Probably. But I don't have time to pull apart and check. Just want it back on the road.
shopman - Cheers for the link .. time to find out shipping to the UK.
Quick Reply: clutch slave cylinder
