Clutch release fork grease up
I decided to sand down the clutch slave cylinder. Everything went well until I re-fitted the slave cylinder which did not engage with the release fork. A lot of fluid pissed out of the slave cylinder. I topped up the fluid but the pedal is not firm.
This is why I should pay people to work on my car. Any ideas/guidance would be greatly appreciated
The Loon
The Loon
UK Moderator
To bleed the clutch you need to put a clear tube on the bleed nipple then open the nipple while someone presses the clutch in; close the nipple when no more air/bubbles come through. Similar to bleeding brakes.
HTH
Chris.
HTH
Chris.
Originally Posted by lower,Aug 28 2010, 05:24 PM
Have you managed to push the piston out of the cylinder?
You need to get the piston back in, make sure the ball in engaged and then bleed.
I've tried refitting the slave, there is very little room between the head of piston and the release fork.
Is this normal as I'm struggling to get the slave back on unless the boot that covers the release fork is left off the car.
