Clutch problem
Clutch problem
Hey just wondering does anybody know what's up with my clutch.
Was driving eariler and was slowing down to turn and the pedal just dropped to the floor so I tried to pop it back and the pedal flew back and is solid and won't press down.
Had a completion clutch and flywheel fitted a few months back?
Thanks
Thanks
If the pedal is stuck up and won't press now it can't be a fluid issue can it. That would give you a spongy pedal that doesn't disengage the clutch.
Sounds like something is jammed.
No joy as of yet I havnt had the time to look.
The pedal is stuck up now and won't press down.
Had to start the car in gear so I could drive it back to the garage
Yep, I was thinking something like this too i.e. stuck in the released position, but sounds like there is drive which means I'd be thinking the release fork or bearing has come adrift somewhere.
The slave + line sound like they have too much fluid in now so will probably need to be bled in any case.
Piston may have stuck out due to slight problem there, inspect that first,<maybe trying to push and is under psi already.>
also dont these cars have clutch cylinder helper ?<dont know tbh only had mine a month>
if so that maybe fcuk
