Clutch centering tool specs
Hello, can somebody tell me the specs of the clutch centering tool? In friday I´m going to change the clutch and nobody in my country have the tool for centering the clutch..
Balashark, I´m too far from you.. slovakia.. I find the tool on ebay, but in 4days no chance to arrive.. but when you send me the diameters of the oem tool, I will make it in half an hour tomorow thanks a lot
Measure the toe bearing and clutch spline on your replacement clutch kit
A pic and some measurements.....
The small diameter is 19mmx23mm, the bigger is 25mm to the outside of the spline....23 mm to the inside of the spline (you will need the 23 to fit inside the clutch, the length of the splined part is 45mm
Hope that helps
Sent from my GT-N7100 using Tapatalk
Hope that helps
