Clutch / brake fluid
Evening all,
Bit odd but bear with me...
I noticed that on my left boot after being in my car that i had two trickles of fluid that has taken some of the dye off the tip / toe of my boot. I've noticed that I have had the same instance happen on one of my left shoes.
Now the question...
Would there be any way that clutch fluid or brake fluid could leak through in to the footwell? Maybe down the pedal? (Clutch or brake)
Thanks all,
Andy
Now the question...
Thanks all,
Andy
seals on the clutch master cylinder would be my bet. This was a common fault on Nissan GTI-R's, used to end up with fluid dripping onto the mats and eating them. Pop your head in the foot well with a torch and you should be able to see if its wet.
