Clicking and clonking from the rear
I have noticed a clicking noise when driving over rough uneven roads from the rear passenger wheel area. When I turn left relatively hard I hear a worrying clonking noise from the rear......
I do sometimes get a loud rubbing type noise when going over speed bumps also. I was told to check the headlight adjusting sensor which I took off, cleaned and regreased. This didn't stop the noise unfortunately.
Anyone got any other ideas of the cause? Starting to think I shouldn't be driving it now.....
Wheel nuts incorrectly torqued
One of the nuts that connects the calliper to the carrying bracket has come loose / off causing the calliper to move back and forth - caused mine to clunk like a mofo.
The above is the cheap diagnosis.
Mike
Mike
Originally Posted by mikefifth
Wheel nuts incorrectly torqued One of the nuts that connects the calliper to the carrying bracket has come loose / off causing the calliper to move back and forth - caused mine to clunk like a mofo. The above is the cheap diagnosis. Mike
I've checked all the above and currently have the wheel off and looking for the problem but can't seem to find anything.... Anyone have any ideas? Should there be any movement forward and back on the ball joints of the headlight adjuster?
If you have the wheel off, try wobbling all the parts you can see
Is it catching anything or is the headlight adjuster moving within its holder making any noise? If you have the wheel off, try wobbling all the parts you can see
I've put it back on in the same position. Doesn't look like it would be catching anything.... Does it look right to you? The top ball joint moves back and forth and there's movement where the top bracket connects to (whatever it connects to!! Lol)
I've tried wobbling most things with the wheel off but everything feels tight.
Originally Posted by AlexGJ248
You haven't had the drop links off recently have you?
Clicking makes me think the hub nut:
https://www.s2ki.com/home/2012/09/21...ow-to-and-why/
Not sure about the clonking, worn ARB bush maybe?
Originally Posted by MIP
Clicking makes me think the hub nut: https://www.s2ki.com/home/2012/09/21...ow-to-and-why/ Not sure about the clonking, worn ARB bush maybe?
I'll have to get a mechanic look at the bushes as I couldn't see any splits in the bushes.
