chip removal
chip removal
Hi guys am thinking of having a go at removeing some of the stone chips i have picked up with a touch up pen.
i have a silverstone MY01 do i need to get this from Honda, or is there somewhere else?
any advise would be great.
Many thanks
Many thanks
Originally Posted by M4X-Neil,Jun 28 2006, 11:45 PM
personally would get the Honda touch up paint PLUS a fine brush
Originally Posted by Middlers,Jun 29 2006, 01:07 AM
Some people advocate the use of a cocktail stick for a neater finish.
I have used Honda touch-up paint on my '01 Silverstone and it is a good match for a metallic.
You need to apply the paint to be slightly raised above the surface and then use Langka to rub the blob down level with the surface. Langka is fantastic stuff. It dissolves the blob and seems to blend it into the existing paint film leaving a smooth and level finish filling only the chip indentation and therefore almost invisible
Details on www.langka.com.
However, you have a problem with chips on the bumpers because the bumpers are plastic and the chips form a 'rim' around the dent (rather like a meteorite crater on the moon) so you need to sand down the rim before you can fill in the chip with paint - not easy to do.
I have found methylated spirits to be a cheap alternative to Langka.
Leave paint overnight to dry then use it sparingly on a cotton wool pad (make up remover pad) and just rub with the meths until the new paint is smooth with the surrounding area.
