Changing to poly bushes DIY
Lads i started to cut out the old bolts from the rusty rear bushes in the rear of my s2000 and i nicked the lower rear bar by 3 mms with the grinder and i am very concerned with this. Ie. should I replace this bar or will I be ok(fingers crossed).
Any help would be greatly appreciated.
Its the bottom of the suspension thats connected to the bottom of the shock and ball joint by back of the brake disc. Its the triangular piece, sorry no pics. will have to get too pics. tomorrow.
You'll be alright mate...just try not to do it again! You may want to invest in a reciprocating saw and some decent blades to remove seized bolts. There's less chance of cutting something else when compared to an angle grinder.
Yeah, you'll be fine. If you are really worried, you could always blend it out to remove the stress concentration point, but I am feeling that is overkill and we aren't dealing with aircraft here!
Originally Posted by irishhondafreak,Mar 30 2009, 07:22 AM
Blending in. Does that mean I should get a welder to fill it or just smooth off the area with a little grinding.
