Changing front struts
Cheers - a couple of things to try. I replaced the rears yesterday and what a PITA it was trying to line up the holes on the bottom on the strut with the bush on the lower arm. I'm going to give the fronts a go this afternoon.
Cheers
Cheers
Yes upper arm no ball jpunt
A lot of folk seem to say the releasing of the upper arm is not enough.
it was for me I just had to push down on the lower arm with a crow bar to make a little extra space.
I believe that's ok
I believe that's ok
I think I was told that when replacing the rear shocks you must have the weight back on the wheels before tightening the bottom shock bolt, I could be mistaken.
No problem with just removing the top wishbone bolts , this give more than enough space to remove and install OEM and certainly meister Coil Overs , didn’t find the bottom bolt much of a problem either.
rear even easier , took Meisters off and fitted OEM in about an hour !
I just followed the post before mine, never check sell by dates either- much to the annoyance of the Boss lady.
