Changing front discs and pads
#22
Originally Posted by eSeM' timestamp='1347480471' post='22007197
[quote name='AquilaEagle' timestamp='1347480197' post='22007182']
Why not? eSeM is one of the most experienced here Captain.
[/quote]
It doesn't make air magically disappear, it makes a small opening in the master cylinder that allows the air bubbles to rise back into, nothing magic just gravity.
#23
In theory it shouldn't work, when you have pressed the pedal you have closed the one way valve that allows to create pressure,so air can't return to the reservoir until you release the pedal, but years ago we did use this method on our motor bikes by tie wrapping the lever up over night, and sometimes it did work
#30
Could someone explain it a bit more. Are the bleed nipples opened at all?
I know clutchs work well by opening the bleed nippl and leaving it to gravity bleed for 20mins.
