CEL, what to do next?
Old 04-14-2009, 09:14 AM
eho
eho's Avatar
Default CEL, what to do next?
Recently my S throws a CEL. According to the scangauge, it is a miss-fire code in chamber 3 & 4.
Since then, I had cleaned the Spoon air filter, gave the throttlebody a good wipe, had new spark plugs installed. However it still occasionally re-throws the same error code when the car is idle and/or driving at low speed (below 10mph).
If this is relevant at all I notice that the old spark plugs have progressive carbon build up from 1 to 4. (Chamber 1 being almost no carbon build-up and chamber 4 plug end was literally brown).
Am I right in thinking the next step is a new engine loom (breakers / new from Honda) and possibly a pressure check on the cylinders?
Old 04-14-2009, 09:26 AM
eSeM's Avatar
Mugen888 was getting this when he swapped from an OEM to Mugen ECU.
IIRC he had is valve clearances checked and reset and this fixed the problem.
Old 04-14-2009, 09:48 AM
veehexx's Avatar
+1 for clearances.
i got cel on same cylinders - turned out to be 1 single knackered lobe on the camshaft - the theory is the same; excessive valve clearances.
ps - the mis-fire code is not exactly true. think of it more as a 'reduction in power' fault code.
i'd also try swapping the coil packs (units that go directly ontop of the spark plugs) between cyl 1&2, to 3&4 and vice versa. see if the fault code moves.
also, as another thing to try - injector cleaner. i'm sure i've heard of others with dirty injectors on these forums....
Old 04-14-2009, 11:06 AM
MB
Member
MB's Avatar
Do it methodically.
It could be a lot of things causing a misfire code.
Guide in my signature will give you some clues.
Old 04-14-2009, 12:38 PM
U9aXy6Dn's Avatar
If you're struggling to start in the mornings or it's taking more time to turn-over, it could well be a coil pack.
When my car did it's coilpack it'd also been gradually killing my red top battery which are supposedly rock-solid - and bearing in mind friends have jumped some huge cars off of it in the past i was shocked.
Old 04-15-2009, 12:08 AM
willf's Avatar
Valve clearences are a good starting point - plugs give a very good indication as to how your engine is burning - if they are different colours, it is not burning efficiently...
Valve clearences could cause this (along with all sorts of other things), so do this first and try it!
Old 04-15-2009, 12:18 AM
eho
eho's Avatar
The car starts no problems even when cold.
Old 04-15-2009, 12:24 AM
eho
eho's Avatar
Thanks for all the inputs
What I do first is to re-arrange the coil pack, see if the code moves to the other chambers. I will run this test for 2 weeks (since it is a weekend car)
If the code don't move then it means my coil packs are okay and a valve clearence check is next.
I keep you guys posted.
Old 04-15-2009, 02:20 AM
MB
Member
MB's Avatar
Coil packsa re the easy place to start.
There are also plugs and injectors to think of if the misfire codes dont move.
Old 04-16-2009, 06:53 AM
eho
eho's Avatar
Plugs are brand new so we can rule that out.
Where can I get hold of some injector cleaners? It is easy to do myself?
Quick Reply: CEL, what to do next?
