Cat spring loaded coupling bolt things...
Old 06-10-2010, 04:52 AM
  #21
Benjamico's Avatar
Stupid question, but have you checked the cat you took off to see if the ring shaped (Doughnut) gasket is stuck in the recess?
Old 06-10-2010, 05:30 AM
  #22
mikey k's Avatar
Originally Posted by Irvatron,Jun 9 2010, 09:58 PM
I know ebayman - wheres Adrian
TBH i now have a gasket for one side which i bought off mikeyK (for this reason), depending on if i can get through the MOT :wink :wink: i might have to put the CAT back on and use the gasket.
That's the flat gasket other end of the cat/decat though.
The doughnut gasket is ALOT bigger and designed to allow the cone in the cat/decat to rotate around.
The springs are there to keep enough tension to sea lit but still allow movement.
If you don't have them how do you know how much torque to apply and how are you going to prevent crushing the doughnut?
Old 06-10-2010, 07:12 AM
  #23
m1bjr's Avatar
You cant crush the donut, you donut
Thats why Honda fit those limited length bolts and springs.
You tighten the nuts right up on the spring loaded bolts until they hit a backing washer.
You cannot over tighten them and collapse the gasket cone or the springs
Then you torque them up if you can, but its no biggie, just use some common sense and dont swing on them you'll be fine.
As Mike rightly says its to allow some angular movement as the engine twists on its rubber mounts.
If you rigid mount it something else will break with the stress, probably your manifold.
Steve.
Old 06-10-2010, 07:42 AM
  #24
mikey k's Avatar
THat's my point if you replace the spring bolts with normal ones you will probably crush the doughnut you doughnut
Old 06-10-2010, 02:06 PM
  #25
m1bjr's Avatar
Krispy Kreme.
Mmmmmm
Old 10-20-2011, 12:41 AM
  #26
cat5cable's Avatar
This post has just saved me a shed load of problems
cheers guys
ginger
Define198
04-23-2015 08:44 AM
loftust
05-06-2010 09:45 AM
ckim715
11-22-2008 09:20 AM
Si2k
05-06-2007 04:10 AM
Quick Reply: Cat spring loaded coupling bolt things...
