Car wont start, battery seems fine
After searching for relevant topics on the forums and net, i cant seem to find help to successfully diagnose the problem. The car wont start and the battery seems to be working fine, bought it less than a year ago in Halfords and i drive the car several times every week. I have a good jump starter and even tried to add a bit of juice for 20 mins but to no avail... The starter is working since i clearly hear it after the click, and the same applies to the fuel pump, however, the "second half" of the fuel pump "sound" does seem somewhat different, slightly fainter i would hazard a guess? Also, something strange, the "start procedure" seems to want to automatically repeat itself after i push the start button, never happened before so not really sure what that might mean, the ESP light also stays on after i click the start button, not exactly sure if that is normal or not.
I greatly appreciate all the help and advice in advance.
If you take the battery back to Halfords they will be able to put a tester on it and see if a Cell has died on you. Have you checked the voltage? Tried using another battery or using jump leads from another vehicle or a jump pack.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
ryanswhites2k
16
09-08-2009 02:32 PM
