Car shakes at 75mph+
Old 04-20-2010, 02:03 AM
Nezquick's Avatar
Hmm. It had a 4-wheel alignment done, not just the front wheels. I think this is narrowing down to possible incorrect balancing of the rear wheels.
Either that or I just drive to work and back over a really bumpy section of the A14!!
I could have sworn it didn't do it before I took the hard top off though and I had all my wheels aligned/balanced/refurbed before I took that off.
Old 04-20-2010, 02:13 AM
s2konroids's Avatar
Worth pointing out, have you damaged/hit one if the alloy wheels?
A slightly buckled wheel could easily cause this.
Old 04-20-2010, 02:20 AM
Nezquick's Avatar
Surely this would have been picked up though when the alloys were refurbished and balanced?
Old 04-20-2010, 02:33 AM
Bassoctopus's Avatar
Have you checked yoru tyre pressures since the change?
I find tyres are rarely set to the correct PSI after they have been fitted. Teg came back at 23PSI on one corner
Old 04-20-2010, 02:50 AM
Nezquick's Avatar
Ok - I will:
1. Check the wheel nuts;
2. Check the tyre pressures;
If that fails, I'll take the car to the garage for the wheels to be re-balanced and checked.
And if that fails....sod it...may as well book in for a Geo check somewhere and get it sorted out properly just to make sure everything is as it should be.
Cheers for your help folks.
Old 04-20-2010, 03:11 AM
unclefester's Avatar
Did they align the valve marks on the tyres with the valves on the wheel? I'd also suspect bad balancing - some places don't get it right first time depending how fast they span the wheel on the balancing machine.
Old 04-20-2010, 03:14 AM
Nezquick's Avatar
Not sure to be honest - is there a mark on the outside of the tyre to show where that is? If so, i'll have a look and check.
It's really annoying me though at the moment!!
Old 04-20-2010, 03:28 AM
Yup, think they are red dots on my tyres - it should align with the valve on the wheel. EventTyres got it right
Old 04-20-2010, 03:59 AM
CHIPPO's Avatar
I am running a set of refurbished wheels, powdercoated, and noticed that the wheel nuts didnt do up properly and needed to be checked several times. Upshot was I sanded down the powder coat on the mating surface which was fairly lumpy and the wheels were not sitting snuggly on the disc. Also copper greased the studs.
Old 04-20-2010, 04:26 AM
J_D
J_D's Avatar
Make sure one of your calipers isnt seized, go for a drive and check the car rolls freely and check the temperature of the discs, see If any appear warmer than the rest.
Quick Reply: Car shakes at 75mph+
