Can you boil clutch fluid?
I remember on my Civic, changing the fluid wasn't actually part of the service schedule, but I changed it when I changed brake fluid (same fluid, see!).
How easy is the clutch fluid to change?
I know on some hydraulic clutchs it can be a pain to get all the air out and they recommend using a vacuum source to draw the fresh fluid through.
The S is one off those clutches that likes to make it difficult.
I've been read posts in the US on removing the clutch delay valve on +04 cars and a fair few struggle to bleed it properly
The way I changed my fluid was basically to pump it out using clutch pedal but making sure the level never dropped too low, basically like bleeding it but bled it enough to make sure new fluid was coming through, worked a treat only took a few minutes.
Its done 10k since then and has been perfect
Rick
Rick
RE- Boiling Points: (according to lucas trw)
Dot 3 = 240 c dry 149 c wet
Dot 4 = 270 c dry 163 c wet
Dot 5.1 = 270 c dry 185 c wet
I take the wet figure to mean contaminated (i.e moisture/water in with the fluid) and the dry to mean "fresh" fluid.
