Camera Mount
#23
What a great idea(s)! One blue lamp being mounted this week-end powered from the socket. Will try the gatso also but will only be able to use it whilst stationary or some difficult calculations come up.
#27
Originally posted by rahula
Looks good to me. Have you had the same problem as StevenM who advised that the rear view mirror was getting in the way when filming forwards? Here is the other thread
http://forums.s2ki.com/forums/showthread.p...threadid=183283
#28
Filming to rear is OK.
Filming to front I tend to have telephoto on and the results are quite acceptable.
At the Blurter Meet I shot some great material - or so I thought - until I found that I hadn't switched the darn thing on!!! Or if I had left it in 2Standby" mode it switched itself off after 5 minutes!!
Need a Navigator!
Need a Navigator!
#29
Did the same thing with mine, but removed the wind deflector and drilled the hole under that. That way, when im trackdaying i take the deflector off and mount the camera and when im not no nasty hole
#30
[QUOTE]Originally posted by AdrianEagle
