The build so far
#571
it is indeed a neat instal, it looks good, and yes its a turbo blanket, gets very hot being up there
top brace, not sure, but i think they dont do much for the S anyway, i have the lower Muz brace on
#577
Watching top gear the other night a clarkson was shouting about the fezza he was driving having 500hp and your has over 600 ..........bonkers
I've been following you project from the begining phil and look forward to day i get to see your car in the flesh.Not much longer for you to wait now
#578
Laskey built block :
Benson sleeved block 9.1 comp ratio
Benson balanced and micropolished crank
CP custom pistons and rings
Pauter rods
Acl bearings
blueprint and assembly
Built head:
SuperTech Stainless Steel nitride coated valves,
dual valve springs,
titanium retainers,
competition 3 angle valve job,
Mase Engineering designed custom turbo manifold and IC tubing
2.75 downpipe
Precision Turbo ( gt35r) will get the exact spec number later
Precision Intercooler
Tial Wastegate
Tial BOV
Rc1000cc injectors
Walbro 255 fuel pump
AEM EMS
AEM 3 bar map sensor
T1R 70 mm Sparrow exhaust
Turbo blanket
Custom valve cover
all new chain, tensioner, pulleys etc etc
Koyo rad
Fal fans
plugs, coilpacks
Drivetrain etc:
Puddy Diff:
cryogenically treated rear, that is every part is cryo treated that can be.
Fully built and reinforced housing that can hold upwards of 200,000 PSI stock is upwards of 60,000 PSI and our Comptech style is 130,000
New bearings, seals, and hardware are used
Fully de-burred and polished gears
Black phosphate finishing (same process used in firearms )
Solid custom sleeved pinion (no crush collar) 10/20 mandrel steel (seamless)
Fresh paint on the housing
Full assembly of rear using precision accuracy to factory tolerances
Competition Ironman clutch
Competition lightened flywheel
KW3 variant coilovers
Muz front lower brace
Rear Subframe new
drop links
Cryo'd rear brakes and refurb
Brembo front rotas
Hawk pads
Cusco brake master cylinder brace
New soft top with glass
Ap2 V2 wheels
many hours of Mase work
i am sure there is more will think abit more and add
Pauter rods
Acl bearings
Built head:
dual valve springs,
titanium retainers,
2.75 downpipe
Tial Wastegate
Tial BOV
Rc1000cc injectors
AEM EMS
Turbo blanket
Custom valve cover
Koyo rad
Fal fans
plugs, coilpacks
Drivetrain etc:
Puddy Diff:
Rear Subframe new
drop links
Brembo front rotas
Hawk pads
Ap2 V2 wheels
