Buffeting - soft top up
Did this to mine, dead easy to do. Before it sounded like a force 10 gale coming into the car on the motorway, after compleatly gone.
he might mean hardtop strikers as opposed to the soft top ones. I'd try adding shims first as suggested above, that may well cure it. IIRC 2mm or 3mm shims between the striker plates and the screen frame should be enough.
Fitting is dead easy.
Remove the left and right A pillar trims.
Unclip the light cover
Unscrew the two bolts and drop the light unit down and unplug it.
Remove the left and right visors
Pull the plastic screen trim down so it unclips
Unbolt the striker plates and either add shims or replace the plates with new ones.
Put it back together.
Can be done in less than 20 minutes
