Brake fluid
Brake fluid
Hi,
I'm getting the S2K serviced next week and since the brake fluid needs doing I thought I would get goodridge lines fitted and Motul put in it.
I've bought three 500ml bottles and now I'm starting to wonder if I've got enough. Using the search I've come up with either two bottles or two litres.
Has any one done this lately and how much do you need.
Thanks.
Thanks.
Bugger, I've just bought 500ml of RBF600, thinking that was enough to bleed the brakes.
Originally Posted by eho,Apr 15 2008, 05:34 PM
the rest of the fulid you can use it change the clutch fluid
But if you're changing the hoses (i.e. introducing air), I'd have more to hand. Mine took lots of bleeds to get it good again.
I don't think there's any problem with keeping the unused bottle for next time, but if you open it you should use it or throw it away.
