Blown Speaker???
Old 03-20-2004 | 09:48 AM
zero_to60's Avatar
Default Blown Speaker???
was topless this morning.......cranked the volume up to much with loudness on and full bass and 'spoltjtcchcebebcbeenbsbmabsmbabebbe'............. .....................
right had speaker is now ed.......I thought it might be a loose wire but took the door panel off and the wires to the cross-over were fine
Is it possible to blow speakers from a head unit....?....I assumed it would be impossible
Old 03-20-2004 | 09:56 AM
JamieS2K's Avatar
Have you the bog standard speakers?
Old 03-20-2004 | 10:33 AM
zero_to60's Avatar
no they are replacement ones.....
not in any hurry to replace as I don't listen to the stereo much anyway
The fezza never had a stereo.......and didn't need it to be honest
LLOYDJ's Avatar
If they are the standard speakers then it's very easy to blow them! Done it myself the first week i had the car!
The standard Honda speakers are a very low wattage, 15 watts if i remember correctly!
Old 03-20-2004 | 10:37 AM
Bassoctopus's Avatar
You can blow pretty much any speaker from any headunit if you try hard enough. Speakers are usually blown when the amplifier is pushed too hard and distorts the signal, squaring off the wave.
It's a myth that a higher wattage speaker will not blow from a low watt amp, indeed it is very likely that this can happen. The trick is to match up wattage between the amp and speakers and make sure that the impedence is right.
Old 03-20-2004 | 10:59 AM
zero_to60's Avatar
it's defo ed.......trouble is when you've got the top down there is a temptation to crank up the volume
Old 03-20-2004 | 11:03 AM
Have you got rear speakers? That should get you the extra volume without risking blowing the speakers.
I haven't got any because, like you, I don't listen to the stereo much when I'm driving the S, but it is something I'm considering.
Old 03-20-2004 | 11:05 AM
Dracoro's Avatar
just as a side note. On my old S, the speakers were distorting a lot like they were blown. Then I realised that on the radio it was fine but not on CD changer. Basically the cable in the back of the headunit to the CD changer was loose. I firmed up the connection and all was well. No need to take anything apart as you can reach the back of the HU with your hands under the dash.
Probably no help but worth a try nonetheless.
Old 03-20-2004 | 11:27 AM
zero_to60's Avatar
anything is worth a try...........
Kenny_Stang
07-31-2017 10:46 AM
rpmgem
06-29-2017 04:40 AM
BSM139
07-17-2012 08:34 AM
Shopman
01-13-2011 05:43 AM
mpease0603
05-01-2007 03:23 PM
