Bit of difficulty engaging gear whe cold
Old 05-09-2005, 01:42 PM
MB
Member
MB's Avatar
Thumbs up Bit of difficulty engaging gear whe cold
I park facing forward so on a morning I start the car and it never wants to go into reverse very easily. I put it in 3rd then neutral and goes in fine. No probs whatsoever when warm. Can I assume putting some proper gear oil in there is going to help me? Seems like the gears just need a slight fraction of a turn and this allows it to engage...
Ta
MB
Old 05-09-2005, 01:48 PM
robs_silver_s2k's Avatar
common problem 2nd gear is also a usual suspect for being awkward when cold
Old 05-09-2005, 01:52 PM
MB
Member
MB's Avatar
Thanks Rob. Anyone cured / improved it? I think some good gear oil might help, so ill get some in and report back. The fact that its ok when warm suggests some mechanical stick when cold to me and a better oil may sort it.
MB
Old 05-09-2005, 01:54 PM
Nottm_S2's Avatar
MB
i get this too.. some people have reported an improvement with new oil
Old 05-09-2005, 02:04 PM
Saxo Boy's Avatar
Noticed this too - put it down to normal behaviour until at normal temp at which point I feel like I'm having sex with every gear change its THAT good
Old 05-09-2005, 02:08 PM
Yep new gear oil always helps. I changed mine twice in 15,000 miles - does make a difference for a while
Old 05-10-2005, 12:32 AM
Mabada's Avatar
Mine does this in second until it's warm - I've got used to easing it into 2nd when cold. Once warm its fine.
Glad to hear it's fairly common - I keep thinking of the long term Autocar one a few years ago that needed a new box.
Incidentally, the EVO long termer report this month mentions jumping out of gear! Scary!!
Old 05-10-2005, 12:46 AM
Dracoro's Avatar
The reverse thing (and low gears) is common in all sorts of cars. The crank is going round slowly, the oil hasn't had a chance to flow round the gearbox, and the low gears & reverse have tighter gaps for the teeth to get in. Something like 3rd is ok so putting it in 3rd then into 1st/rev is enough to move the cogs and oil around a bit thus making 1st/reverse easier to engage.
Could be wrong but that's how I see it. Must go read some about gearboxes
Old 05-10-2005, 01:16 AM
Bassoctopus's Avatar
Redline gearbox oil seems to have improved mine noticeably
Old 05-10-2005, 02:01 AM
sammyc's Avatar
Hey Rob, you got your new motor yet?
Quick Reply: Bit of difficulty engaging gear whe cold
