Best Way to Remove Cat Stud?
was looking at my cat the other day after I removed it and realised that my decat and HFC had been given back to me without nuts and bolts. I assume you've bust one of the three on the down stream side.
On my cat the studs are splined and seem to be a press fit into the flange, they were also fairly well corroded, odd as the cat has only done two 6 month shifts.
How about a large socket over the head and see if you can use a similar size bolt and a G clamp to press it out.
they punch out but you need something substantial behind the flange to get them to shift, if you must do it whilst still on the car then you need a 90 degree angle chuck for the drill then drill it out starting with 3mm pilot and work your way up, its quicker to take the cat off
