Best adhesive for patching a hood?
I'd use the search but it seems to be down again Anyway, I remember searching a while back and found these products on this page;
http://www.seaskin.co.uk/acatalog/Gl...cessories.html
The Stormsure and Neoprene Queen look ok but has anyone has any experiences? Or should I take it to a specialist and get the patch 'welded on' to the hood? The little tears are the ones where the a-pillar should be, so want to sort it before it gets worse!
Cheers.
Cheers.
Not really; these were expensive cars once upon a time and they were treated accordingly and a new roof fitted, if the old one was sufficiently neglected to tear.
Adhesive is not usually an acceptable solution for a variety of reasons.
Most people have used those 2 adhesives and have found them to be okay - AFAIK.
I couldnt remember the names of them before sorry, whatever you dont use bicycle repair kit adhesive like some people it doesnt last 5 minutes.
Can't offer any oppinion on the glues but I can suggest you try Tear Aid
http://cgi.ebay.co.uk/TEAR-AID-Repair-Patc...=item2eaa09efba
IKWYM, but it depends why it tore; either the material had worn thin, or was under excessive tension or both.
A 1cm tear is likely very quickly to end up a 1" tear and so forth...
