bad cat
bad cat
hi all, cars in for mot tommorow i been having intermitant cel, code p0420 so we will see if it passes. if it does pass, do you think that anti foulers will keep the cel away with the standard cat thanks
Member
Jamie,
Im confused. Do you have a standard cat or a decat?
If its a standard cat then antifowlers will make no odds as the MOT uses their own oxygen sensor.
Originally Posted by Dark Blue Mark,Apr 11 2007, 12:45 PM
Jamie,
Member
If you have a genuine CEL then you dont want to be hiding it by any means of jiggery pokery.
The fault is generated when the secondary sensor decides things are a bit rich.
You need to find out what is causing it.
More than likely your cat is buggered and it would fail on emissions, rather than just having the CEL on the dash...
Member
Id then suspect your secondary sensor may be playing up if it passed ok.
Not much I can advise over the net on that, is it will need a diagnostic to plug in to see its voltage.
I will do some digging though...
