Audio Control Pin Diagram
Hi All
i have a 2004 S2k the audio controls (where the start button is) does anyone know the wiring diagram / Pin layout for these etc the volume, mute etc and also what each wire is positive or negitive.
Do they not run through a CAN BUS system? Hope they don't as I want to hook mine up to the carPC.
I've not got round to checking the back of the panel for connections yet
As I put a AEM gauge in mine I had to cut through the board inside for it to fit in place so I was going to try and make up my own control board to work with my unit but I need to know the pin layout of the plug
Originally Posted by stu_c,Dec 18 2010, 04:22 PM
do u know if it would be possibble to make your own audio switches?
All possible but may need some additional circuitry ??
Originally Posted by hammyS2,Dec 18 2010, 09:34 AM
I take it you mean buy alternative aftermarket switches Stu? Must admit that concept has crossed my mind as I've always wondered why such a large Mode button was used that doesn't toggle (control stick fashion - left, right, up, down). Be interesting to see if anyone has applied this principal to perhaps the Modifry unit where you can perform additional functions using the existing controls (on some head units) by pressing more than one function button.
Stu - when running through this thread again I noted garyo's link which holds the key. It's been a while since I've dabbled in the electronics world although you could measure the resistance from the OEM switch when held in the + and - position then replicate this with your own components. If you were to buy a rocker switch from RS/ Maplin/ wherever then I assume some soldering of the resistors will be required.
I'm sure some bright spark (excuse the pun) on here will be able to provide better guidance though.
