Audio Advice - Which speakers Front & Rear (+maybe in Roll Hoops) + Installation Help
#21
If you're running an amp good luck trying to feed the wires through the door! especially the left passenger side door, it is mega tight, you need to lube the cables and poke it through with something like coat hanger wire. Try buying good quality thin cables. Also make sure there are no leaks in the boot cos water might get in the amp!
