Anyone Know What Strut Brace This Is?
Old 04-21-2010, 09:18 AM
Nick Graves's Avatar
Originally Posted by loftust,Apr 21 2010, 04:49 PM
The chassis on the S is different to most. It flexes at the bottom, not the top
...unless you brace it @ the bottom & then it starts flexing at the top.
That's why it takes a Cray to calculate FEA...
Old 04-21-2010, 09:32 AM
UK Moderator
chrisr111's Avatar
Originally Posted by eSeM,Apr 21 2010, 06:11 PM
I didn't think a genuine Mugen filter would have the big gap in it, like the one in the photo.
Ahh I see.
Maybe someone had the foam cover off to clean it and not put it back on properly.
Chris.
Old 04-21-2010, 10:07 AM
MUG3N's Avatar
Originally Posted by loftust,Apr 21 2010, 05:23 PM
Front Uppers are useless anyway
So do most who have fitted them.
Old 04-21-2010, 10:42 AM
S2K Tuning's Avatar
Its a Cusco ALC OS.
Old 04-22-2010, 12:11 AM
oxhouser's Avatar
top struts are not part of suspension geometry on the S and as such any flex between strut posts has no effect, only one i would think has any benifit is the one
http://www.vtecdirect.com/online/cgi-bin/c...T--ASM-AP100117
as it triangulates the bottom subframe preventing twist
Old 04-22-2010, 12:31 AM
punchdrunk's Avatar
Originally Posted by plastic91,Apr 21 2010, 04:46 PM
Structurally speaking, an addition of a top strut irrespective of quality of material will only stiffen things up.
However nasty the product, i can't see how it will make your car drive worse. I would just leave it on.
It made zero difference to mine.
To the OP, I'd leave it where it is or sell for £100 or so - you decide.
Old 04-22-2010, 12:45 AM
Oh, if you think it has no effect, then that's alright then.
I'll tell Honda to retro-remove the strut braces from the EK9 & NSX-Rs then!
Old 04-22-2010, 12:50 AM
loftust's Avatar
Different chassis'
Old 04-22-2010, 02:12 AM
oxhouser's Avatar
If I’m not wrong the civic uses a McPherson strut making the top mount part of the suspension geometry so a brace helps here
if i was being cynical i would say the NSX after years of fine tuning some of it by Senna reached the showroom without a brace so adding one to a type R version could just be marketing, i cant say as i have not looked in detail at the NSX set up, i have looked at the S and cannot see how bracing the top affects movement in the suspension location points, a brace will only prevent the towers from moving inwards or outwards, it will not stop them moving up and down unless they are cross braced.
not trying to piss on anybodies parade here just my thoughts on the issue.
Old 04-22-2010, 02:15 AM
UK Moderator
chrisr111's Avatar
Nick is talking about Civics (EK9, EK4, EG6 etc.) with double wishbone suspension.
Early NSX coupes (NA1), which Senna had input, had the rear strut brace as standard, not just the NSX-R.
NSX targas have even more bracing.
Chris.
Quick Reply: Anyone Know What Strut Brace This Is?
