Anyone fitted Deatschwerks injectors?
#21
Originally Posted by mr-pitts
Do they seat nice into the inlet Mani?Some that I have fitted looked similar bu what I did was used the seals at the top of the injectors and to be double safe I put rubber O rings that pinched between a collar on the injector and the bottom of the fuel rail,just space the fuel rail enough so that when you nip it up it squeezes the ring quite tight.Once the top O rings seals the larger o rings on the outside is just extra insurance......I you get what I'm saying.
It doesn't really matter if the fuel rail doesn't bolt right down to its original position provided it buts up the the injector collars,is squair and obviosly it all needs to seal with no leaks.it WILL be obvious if it's not sealed once the fuel pump has primed,and provided you don't start the engine it's easy enough to clean up.
#22
Let us know how you get on Chris as i was planning on fitting mine over the winter. Abit annoyed that they aren't plug and play especially as they list as being a straight swap
#23
Will do. I've just had a 2nd reply from DW saying that the rubber 'bumper' that should sit flush up against the rail is just a dust cover and does actually seal. I kinda knew that, but I actually said there was a 5mm gap and if I tighten the rail down, the dust seal gets deformed, which doesn't look right. Not exactly a comprehensive reply! Alex at TTS is back in tomorrow so Richard has told me to chivvy them for a response first thing. They've clearly fitted them before, so I'll just do what they do. Judging by Yorkie's reply, it'll likely involve a little spacing. Not a problem, happy as long as it's worked for others. I just want a proven solution.
#24
I messed about for ages thinking I was doing something wrong with them. Only way was to space. It seals fine and I've had no issues apart from the cover won't fit back over the rail. Really shouldn't be selling them as a drop in oem fit injector though. Far superior to rc's though and better priced than the ID ones. I'm pleased with mine. Much better idle and drivability and easier to map than the rc750s I had previously.
#25
Cheers, glad I'm not the only one!
#28
Well i had a go at fitting these last night and tonight.
Firstly old stuff comes apart easily enough and the injectors came off with the fuel rail leaving the rubber cushions in the inlet manifold. When i removed the fuel pressure regulator from the rail the O-ring disappeared into the depths of the engine bay.... Oh joy.
I run into the same issue that Chris had with the double o-ring. I carefully removed the second o-ring but made sure i kept them. I spaced the 3 studs with a total of 2mm of washers per stud. The main issue is that the injectors were a loose fit in the rail with just the single O-ring. It wasn't very reassuring how loose they felt in the rail. I decided to put it all back together and give it a go. One massively handy option on the AEM ecu is being able to set how long it primes the pump so i set it on its max and left it priming and listened and looked.
It didnt appear to be leaking but then i found traces of fuel on the injector body closest to the bulkhead. I took it all apart again and made a point of tightening down that side of the rail first to make sure it sat in properly. Primed it and it still leaked... I was getting abit pissed off now as it felt like these injectors might be ready for the bin.
I stuck the second o-ring on all the injectors and pushed them into the inlet manifold and tried again to refitted the fuel rail. It was tight and you can only just get the nut on the thread but it seemed to do the trick. The rubber parts on the injectors at the top in my eyes are designed to deform abit as the rail pinches down on them so im not overly worried about them being squeezed and it also seemed to help keep the injector tight in the rail. I imagine the 2nd o-ring is either mashed up against the fuel rail lip or more likely been forced in to the rail and will help with the seal.
Primed the car again and finally no leaks and i was happy enough to start it. After abit of a stutter the car ran with a slight missfire for a few seconds and then idled nicely. Infact it was idling at 14.7 which isn't bad when you consider i only used the AEM injector recalibration to get a rough idea of starting fuel.
I will check and check again tomorrow for any leaks. Im abit paranoid as only yesterday my brother had a deatschwerks injector fail on his mini nearly causing a fire as it sprayed fuel all over the engine and bonnet.
Will be interesting to see how Chris gets on fitting his and whether he runs into the same issue with only using one o-ring.
#29
Useful stuff, thanks. I've got mine fitted (single O-ring and a set of thick washers) but I need to install a couple of sensors before I get it all fired up, so it might be a couple of weeks. I'll report back for sure. I'm not convinced there's enough force to seal properly at the moment but we'll see.
Is your leak from the rail side or the manifold side of the injector?
And on another note, how did you get to know the AEM software? I'm about to start with a base map fro Romain but if you found any decent guides, it would help me get into it a bit quicker.
#30
I got a copy of the AEM manual and spent a fair bit of time messing about with the software and learning the important things. I paid AJ to map my car via datalogs so i could learn what he was doing and ask him questions. There is a guy who has posted loads of videos on the AEM ECU and its features and how to use them. I think they are on youtube
