Any1 know if ITR brembos fit behind 17" OEM wheels
Old 01-11-2007, 01:52 AM
SiDHEaD's Avatar
Default Any1 know if ITR brembos fit behind 17" OEM wheels
Not sure what brakes will fit behind the oems 17s (MY04)
Old 01-11-2007, 01:55 AM
lower's Avatar
Do the ITR brembos allow you to fit a thicker disc?
Old 01-11-2007, 03:24 AM
eSeM's Avatar
Not a lot .....
Spoons would almost certainly fit, Wilwoods probably wouldn't without spacers and proper Brembos I would doubt very much.
The RSX/DC5 uses exacly the same barake fittings as the S2000 and these cars come with Brembos but I have been told however that these Brembos are not that great.
Old 01-11-2007, 04:37 AM
SiDHEaD's Avatar
As long as they are better than std ones thats ok, cos they sure look better too, i cant afford to change wheels as well!
Old 01-11-2007, 05:53 AM
Banned
Taikyu's Avatar
The Brembo are poo! no modulation...
The spoons will fit; you need a 15mm spacer though
We are about to release a new 4 pot and 6 pot
The 4 will fit under the wheel with a 33ox28mm disc without a spacer
Ant
Old 01-11-2007, 05:55 AM
lower's Avatar
Spoon calipers don't fit behind the OEM wheels IIRC. Didn't PJL try them and found they didn't fit?
Personally i wouldn't bother upgrading the calipers unless you can fit a bigger and thicker disc. With Ferodo DS2500 pads you get a significant improvement over stock right up until the discs glow red hot. Brake cooling is more of an issue, and the only way you can improve that (excluding cooling ducts) is by fitting bigger discs. (or drilled ones, but they'll crack. even the spoon ones)
Old 01-11-2007, 06:01 AM
reg
reg's Avatar
I know from racing that there are Brembo's and then Brembo's if you get my point? Are they any better than stock as they surely are just production quialty calipers??
Old 01-11-2007, 06:04 AM
SiDHEaD's Avatar
Seems to be a bit of a no goer then The standard ones just look so shat for a "sports" car... Was just an idea... As I thought "hmmm both Honda"
Old 01-11-2007, 08:29 AM
eSeM's Avatar
A full Wilw0od kit doesn't cost that much and I would expect that would fit with 5mm spacers.
These are as good as OEM but will fade less on track days. Also cool down a lot quicker than OEM.
Old 01-11-2007, 08:30 AM
SiDHEaD's Avatar
How much is not much mate? Need to get it past my gf hehehe
Quick Reply: Any1 know if ITR brembos fit behind 17" OEM wheels
