Another seized caliper thread (yawn)
The curse of being a weekend car and the recent monsoon season has finally hit me - looks like I've got a seized front caliper. I had the usual symptoms of one unusually hot wheel that was covered in more brake dust than the others, but I also got a bit of steering wheel wobble, which became much worse when I applied the brakes - a real thumping you could hear and feel through the steering wheel and brake pedal, and there was a constant whirring/rumble.
I left the car until it was time to go home in the evening and it seemed OK all the way (about 37 miles), although I nursed it - no hooning and big stops. All the wheels were cool and no noise.
Anyway, my question is are these symptoms all in line with a stuck caliper, or does it sound like a wheel bearing could be shot too, or anything else? It's booked in to be looked at next week, but curious just the same.
Cheers,
FB
Cheers,
FB
I've had this problem 3 times (an 04 model). The first two occasions were on the front wheels and the symptoms were: loss of performance, a very rough feel to the suspension and of course brake dust/hot wheel. The last occasion was a rear wheel where the symptom was only brake dust/hot wheel. The first time it happened on the front I was too slow to realise what was happening and cooked the pads and disc on the affected wheel (which of course meant changing both discs and all the front pads), despite this the wheel bearings were unaffected!
Thanks, folks. Like I said, it's booked in next week and whatever it needs, it'll get. I was just curious to know if it sounded like more than just the caliper.
I reckon the pads might well be cooked though. I didn't do any heavy braking to really tell, but I thought it felt a bit weak......
Cheers,
FB
Cheers,
FB
These are exactly the symptoms I had on mine last year. A change of front calipers cured it. I fitted refurbished Pagid units (one of the cheaper options), and it's been fine ever since.
Mike
Mike
If the brakes have been seizing it can kill the pads and the discs depending on how much heat has built up. My front passenger side seized the week after i brought the car and i ended up changing both front calipers, discs and pads. Never had any problems since apart from occasional sticking caliper sliders but that is fixed with regular maintenance.
Sounds like a warped disk along with the calliper, but don't change both front callipers for the hell of it, that's like your front door is sticking so you replace it along with the back door as well. I don't know where this change everything 'cos one day it will brake attitude comes from.
The disc has had a bit of a warp mark ever since it was fitted - didn't bed them in properly. Just took a look and it's nowhere near as bad as the pictures Mark has posted - no visible excessive damage, so I might get away with just a rebuild kit. Only Tuesday will tell........
