Alloy Wheels
Old 07-12-2008, 05:09 AM
  #61
marc r's Avatar
Originally Posted by mikey k,Jul 11 2008, 06:10 PM
Marc those are 18" TE37 (I think) what sort of width and offsets?
Volk LE37T 18''
Part # VR LE37T 18 S2K
This includes the 18x7.5" for the front (+48 offset) & 18x8.5" for the rear (+50 offset) in S2000 fitment. These wheels are available only in GunMetal with a Polished Lip.
They are the same as TE37's apart from colour. Offset has already seemed fine, no rubbing.
Old 07-16-2008, 08:38 AM
  #62
s2k_Nut's Avatar
Originally Posted by Ste_Nova,Jul 12 2008, 01:17 PM
right i need help now
i want 17" wheels, but what width do i got for???
i'd also prefer to run 255s like the cr?? is this advisable?
cr wheel specs
Front Tyre Size : P215/45WR17
Rear Tyre Size : P255/40WR17
Front Wheel Size : 17 x 7.0in
Rear Wheel Size : 17 x 8.5in
Read the FAQ
Old 07-16-2008, 08:57 AM
  #63
Ste_Nova's Avatar
does anyone know
Old 07-16-2008, 09:47 AM
  #64
Ultra_Nexus's Avatar
[QUOTE=Ste_Nova,Jul 12 2008, 12:17 PM] right i need help now
cr wheel specs
Front Wheel Size
Old 07-16-2008, 09:52 AM
  #65
mikey k's Avatar
Originally Posted by Ste_Nova,Jul 16 2008, 05:57 PM
does anyone know
You need to consider the offset with the width
All your answers are here!
https://www.s2ki.com/forums/index.php?showtopic=342793
Old 07-16-2008, 10:08 AM
  #66
Ste_Nova's Avatar
i want slipstreams
17x7.5 or 17x8 or 17x8.5
Old 07-16-2008, 10:09 AM
  #67
Ste_Nova's Avatar
can you update that to reflect the cr stuff
Old 07-16-2008, 10:18 AM
  #68
Originally Posted by Ste_Nova,Jul 16 2008, 06:08 PM
i want slipstreams
Max offset for Rota is +48
I'm not even sure you can get the 8.5 wide, but even if you could, I reckon you'd be on for rubbing issues.
Old 07-16-2008, 10:23 AM
  #69
Ste_Nova's Avatar
oem ap2 are 8.5"??
this shows a 7.5 front and an 8 rear
http://cgi.ebay.co.uk/17x8-17x7-5-ROTA-Sli...tem260076652032
Old 07-16-2008, 10:31 AM
  #70
Nick Graves's Avatar
7 & 8.5
Mine are 7.5 & 8.5
17x7.5, +52, 5x114.3, 15.8 lbs each
S2000 (2000-2003) Front Wheel
S2000 (2004-2006) Front Wheel
17x8.5, +59, 5x114.3, 16.5 lbs each
S2000 (2000-2003) Rear Wheel
S2000 (2004-2006) Rear Wheel
The S2000 hasn't got shitty mcP struts, so the offset should remain factory, or close to factory.
What confuses the issue is the Backset of the spokes clearing the brake caliprs, NOT the offset, which should be kept as close to factory as possible, in order to prevent steering kickback & tramlining.
The reason people reduce the offset when upgrading is usually because they are big tarts and want the wheels to stick out because they believe it looks good.
Quick Reply: Alloy Wheels
