alarm issue?
alarm issue?
last night i noticed that when i push the lock button on the fob only the driver side indicator flashes? front and rear, the passenger side doesnt, front or rear, any ideas? i got back in the car and turned the ignition on, turned on the hazzards (thinking it could be a blulb) but they worked, also just tried indicating left (passengerside) and that also worked. just doesnt work when i push the lock button on the fob??? strange. not sure how long this has been doing this for,but i have not long had it back from a repair, (front end) is there anythink that could have been forgoten tobe reconected? checked the fuses and they all seem fine
thanks
thanks
the alarm works fine but when it is activated with the fob only the passenger side indicates also happenes when its deactivated with the fob. both indicators work fine signaling left and right or hazard just not when the close button is pressed on the fob? checked the relays and fuses they seem fine?
there will be a wire connected to the loom for this feed, used the alarm install instructions to track down the wire, put a test bulb on it and see if there is power there, if not it's the alarm
alarm works fine just the passenger side lights dont engage to let you no its armed but the drivers side does? i dont have a alarm instruction book
