Alarm install question
GAP Security fitted a Clifford 650 to my S2 a few weeks ago. I have had a few problems since with the alarm and ended up using the key to lock/unlock the door only to discover the Honda OEM Cat2 alarm was still active! I unlocked the door with the key and the OEM alarm went off! Should the OEM alarm be removed as I now have a Clifford 650?
Also, has anybody else had problems with the Clifford 650 prox sensors?
well i had the same prob when i had to remove my oem alarm to fit my toad cat 1 on my ap1 the main brain was located under the drivers seat.youcan remove the oem alarm but i`d get someone with knowledge to do it.....
GAP fitted the same system to my MINI Cooper S, they also left the OEM alarm in place. I didn't know this was the case until it went off, I was confused at first. Why don't they remove the standard alarm??
Spoke to GAP today about the oem alarm and they said they don't normally remove it unless specifically asked for by the customer. Something to do with the transponder built into the key and standard immobiliser. Sounds like a valid reason...?
Has anyone else noticed if the standard honda oem alarm is armed when you lock the door with the key and not the oem fob? On my 2004 when I lock using the key the red led starts flashing on my dash.
thers 2 types of security devices fitted to your car
1*wher you have the fob which has the central locking
2*the actual chip in the key
you can easily bye pass the oem alarm the brain is located under the drivers seat as for the chip key you cant and thers no way to either but you will not need to ouch the chip key its just a transponder for the ecu.
thers 2 immboliser cuts on the oem alarm fuel/starter....if you need more help pm me....
Ive got an Inteliguard 950 fitted, was supposed to be Concept 650 but got free upgrade due to messing me about. (Basically same alarm but with more ports available for extras to be connected to)
I had to take mine to Honda to take old alarm out cause he said it couldnt be fitted untill this was gone. Cost me
