Air bag warning light
Old 11-29-2009, 04:36 PM
peters2000's Avatar
thanks I will try and sort the abs light first, then once sorted come back to the airbag light, were is the sensor for the airbag? do they have a sensor in the front crash bar behind the bumper? Im just wondering what sets them off.
Old 11-30-2009, 07:54 AM
Dan Hale's Avatar
Is it possible that the previous owner disconnected the mpassenger airbag so they could have a sprog seat in?
I know this would leave a fault light showing.
Old 11-30-2009, 08:45 AM
peters2000's Avatar
very possible! the car is also covered in dog hairs! how do you turn it back on?
Old 11-30-2009, 08:49 AM
loftust's Avatar
You'd have to disconnect something to 'turn it off', so check the connections to ensure it's 'turned on'
Sounds like you need a code reader...might be worthwhile buying one to save yourself alot of bother and narrow down the fault accurately rather than us speculating about what it could be. Most of them can reset codes for you too
Old 11-30-2009, 08:52 AM
peters2000's Avatar
Yes I was thinking that myself any ideas on were i could get a code reader from?
Old 11-30-2009, 08:54 AM
peters2000's Avatar
a make of a decent cheapish one?
Old 11-30-2009, 08:55 AM
loftust's Avatar
eBay? A Geniscan GS300 comes recommended from other members and are cheap too
Old 11-30-2009, 09:31 AM
s2konroids's Avatar
Most code readers wont will read/reset ABS/Airbag lights etc, the geniscan £30 ones wont, its a different system
To interogate ABS faults you need a DTC reader like this...
http://cgi.ebay.co.uk/Pro-Universal-EOBD-O...=item3a5535f399
Geniscan make one buts its much more expensive than £30 your looking at around £170 for one from any manufactuer. Of course it will need to work with the Honda, VW/Skoda etc are VAGCOM so wont work on a honda.
Also I could not for the life of me manage to read my ABS codes with a 'snapon' reader, i had to goto a dealer and pay £45 cash to read the code.
If you've done the bushes its possible you have damaged an ABS sensor/cable i did when i did all the bushes myself, and other have done the same in the past too.
Seems like your on a budget Peter so maybe cheaper going to the dealer pretending your a garage then turning up paying by cash always cheaper that way
Old 11-30-2009, 10:17 PM
peters2000's Avatar
Yes im on a budget, although its more than just for money reasons, I just wanted to see if I could get this car all done for a set price, why spend more than you have too!
Interesting about the reader, Ill try a normal garage that already have one of those readers see if they can pull the code if not ill go to honda and maybe say you can service the car if you pull the code for free!
On my golf you can just turn the passenger airbag off for if you wanted to put a child seat in, doesnt the honda have this then?
Old 11-30-2009, 10:35 PM
UK Moderator
UK Moderator
lovegroova's Avatar
There's about 20 pages in the user manual dedicated to carrying children in the car, most of which says it's not recommended (hence Dan's comment above). Have a read of that, if you've got the manual of course.
FromaDB2toanAP1
05-09-2015 12:02 AM
mrxjeffrey
02-01-2011 12:47 PM
sokkie9
05-17-2008 05:29 PM
Bravnik
03-04-2006 06:01 PM
ImportSport
04-07-2004 11:12 AM
Quick Reply: Air bag warning light
