Aftermarket steering wheel / hub issue
Hi all,
i installed a momo hub and OMP corisca today, everything went smoothly i,e removing the original airbag etc. Since fitting the wheel it seems the steering / rack has gone really stiff, almost as if there's no power steering.
I can't see the boss rubbing any where so it's either 2 things...
- i've done the steering bolt up too tight
- the SRS and horn harness comes out from the SRS wheel at the bottom of the reel, the hole to feed this through on the hub is at the top and it seems the wires have gone really tight.
I think its more the first one, i have read on here that the correct torque for the steering bolt is 29ft/lbs.
Can any one confirm this? unfortunately i can't hold of a torque wrench until tomorrow.
Cheers
Cheers
Have you fitted the s2000 all years momo hub? Think part no. Is 4303 or something. Because if you bought that hub it won't fit facelift models. Forcing it on will no doubt damage something. Put the original wheel back on and make sure the problem goes away. If it does then its a problem with the hub.
how does it look ? i realllllly want this steering wheel pic? Is there a washer to be fitted before the nut ? I really need a new torque wrench my method is just FT (F%cking Tight) which is no good. where did you get hub and wheel?
Hi Dan, yeah i definately have the correct hub, MY02 and there was only 1 option on demon tweeks for the s2000. i will try the OEM wheel tomorrow to see if it's the hub causing this issue.
Dave, it looks great man, here is how it looks after a test fit...
i got a smashing deal on the corsica, won the bid at 70 quid, it's absolutely mint too, think the guy only used it once for racing and was then told he was not allowed to use a deep dish so he had to change it.
the hub was 60 off demon tweeks, i'll probably go with the nrg short hub, i don't mind where the wheel sits, would just prefer it a bit closer to the controls.
How strange, that Momo hub is completely different to the one I got from demon tweeks!?? I have a BNIB Corsica i might be selling soon, i don't know if i like the dish or not, may go for a flatter wheel.
Ellzy that is stunning man, so jealous there is a red suede 330wide, i want i want lol, only in usa and wont post
check it out.
http://www.tf-works.com/omp-corsica-...itanium-spoke/
give me a shout when you are selling hub.
check it out.
charlesardolino8
01-18-2013 07:18 PM
