AEM v2 on 2009 S2000
Hi, I just recently bought a S2000. I read that the AEM V2 fits the 2009 model with slight modifications. When I took it to garage to be fitted they said they can't fit it. They said something along the lines of the air meter hoses are the wrong size and cause incorrect readings.
I did a search and couldn't seem to find anything. Also if the AEM V2 is no go, what is the best alternative induction kit for a 2009 model?
I've got the K@N FIPK fitted to my 2009. Sounds great and no heat soak.
Easy to fit but you will have to drill a hole to fit the extra sensor that the 2006 onwards cars have.
i installed AEM v2 to 2007.
perfect fit.
the only thing was missing is a hole to stick in IAT sensor (tempreture).
drill a hole. put in a rubber grommet. stick IAT in. that's it.
perfect fit.
