AEM Serial Gauge Questions
Hello,
Looking for some concise, clear instructions here.
I have installed the serial gauge, it works.
I followed the instructions and connected the ECU up the my laptop running AEMpro. I turned the telemetry on and selected serial gauge.
The gauge turns on, works fine, I can scroll through different readings which is great, however I am not sure the readings are correct (or being displayed correctly).
H20 which is collant temp reads 32 when car isnt turned on and then rises to 170-180 when fully up to temp. Its reading in Degree Fahrenheit instead of degrees c.
How do I change this? Also how do I know the other "out the box displayed" readings are correct. Speed is bang on the mark. as is throttle position.
I have never done any ECU tuning, please be nice and clear for me!
Mike
Mike
You need to connect the serial gauge to a laptop, then use the software provided to change the units (from memory). I set mine up a couple of years ago now.
If you are really stuck I can email you my calibration file so you can upload it to your gauge?
That would be excellent.
I have hooked it to my laptop but i havent a clue what value to change. I dont want to mess with the nice map i paid for!
No the gauge has separate software. You need to unplug the gauge and calibrate that with a laptop. I can't remember what the softwares called now, but it comes with the gauge.
Mattie helped me with mine.
I'll send you the cal file when I find it. You will still need to use a laptop to uploaded it though.
Thats ace thank you, i think i got myself muddled.
I used my aempro software to turn telemetry on. i was plugging the ems into laptop and then using aemprogauage software but it wouldn't work. Guessing i Need to use progauge with actual serial gauge?
Will reread instructions again
