AEM cold air intake
Old 08-23-2008, 01:49 AM
  #21
s2k_Nut's Avatar
Originally Posted by MB,Aug 23 2008, 10:35 AM
Someone a while back worked out the developed suction head / pressure that the engine can make, and then worked out the lenght of the pipe and I think it was pretty hard to draw in water.
That said, i'd fit some sort of protection if I had one.
http://www.sportcompactcarweb.com/tech/010...alve/index.html
That's a great link thanks for that MB, now I just need to determine my diameter of pipe and get one bought I think
EDIT:: the one thing I will say on further investigation is that the filter has to be completely submerged for hydrolock to potentially happen, rain is not enough, there has to be a vacuum created. This would be pretty difficult to do I guess, I suspect a small but wide and 12" or more deep stream of water or similar would be the type of thing to avoid, as this might give the potential for a lock.
Old 08-23-2008, 08:16 AM
  #22
mikey k's Avatar
Originally Posted by s2k_Nut,Aug 22 2008, 11:46 PM
'Basically, think of a straw. You suck a liquid through it. Try punching holes through the straw midway up. Then try sucking water through the straw. Obviously, you may still be able to suck liquid through the straw being that the diameter of the straw is small.
Using that example shows a problem with this!
Air (or water) is going to take the path of least resistance.
Putting this in is going to negate the lower section of the AEM IMHO
The majority of the air will be pulled through this item rather than the inner wing area of the AEM.
Old 08-23-2008, 10:41 AM
  #23
s2k_Nut's Avatar
Yes thats what I thought, but no ... it is sealed rubber flaps inside and the normally are sealed so the air goes through the pipes, only when there is a vacuum at the filter end do they open and allow the air to be sucked in through the sides of this device. If you look at the link MB posted there are pics of how it works, it's rather sophisticated, it looks simple but not so.
I measured my pipes, and had a look at them (both pieces) the diameter of which are 9.5", I have no idea which size of valve I should by as there are 3 or 4 from which to choose, anyone have any idea?
Thanks
Old 08-23-2008, 10:49 AM
  #24
mikey k's Avatar
That makes more sense!
Problaby easier to fit as well!
Old 08-23-2008, 11:17 AM
  #25
s2k_Nut's Avatar
I don't know Mikey, can you work out which size I would need, checkout my first post for a link to the site that sells them, I can't determine what size I would need
Old 08-23-2008, 11:38 AM
  #26
Blurter's Avatar
Paul - have a look at my holiday review from last year
https://www.s2ki.com:80/forums/index...owtopic=500142
as you can see, we had "a bit of rain", and no problems
HTH
  #27
mikey k's Avatar
No idea on size!
I presume this fits on the throttle body?
Just measure that or ask on the modding forum
Old 08-23-2008, 11:44 AM
  #28
s2k_Nut's Avatar
HTH
Fantastic pics Dave, as ever
I believe falling rain isn't a problem, the only problem is standing water and deep standing water deep enough to cover the filter under the car, if this happens then water can theoretically by sucked up into the engine causing the hydrolock this device reputedly stops from happening.
Old 08-23-2008, 11:49 AM
  #29
LTB
LTB's Avatar
Seriously I wouldn't bother, you really do have to drive through a lake to get lock.
As I said, most happen after being parked up overnight with heavy downpour, the high idle rate of the s2000 sucks the water up when you start the engine.
You've taken reasonable precautions already by blocking the drain plug, but go for it if it'll give you piece of mind.
  #30
s2k_Nut's Avatar
Originally Posted by mikey k,Aug 23 2008, 08:38 PM
No idea on size!
Hmm no i don't think it does, I think it attaches between the two connecting pipes that make up the CAI, but the diameter of these pipes is 9.5 inches the device is sold in 2.5" - 3" but I am guessing this is width, it doesn't make sense I will give them a call next week and in the mean time I will not worry about it and as Dave points out he has driven it through many miles without problem!
Quick Reply: AEM cold air intake
