AEM AFR gauge and wideband installation
Old 03-02-2010, 12:52 PM
s2konroids's Avatar
Default AEM AFR gauge and wideband installation
I recently aquired an AEM wideband gauge and a bosch wideband sensor (Thanks Lloyd). I will be installing this into a dual gauge pod located on the drivers side window pillar.
Now there are 4 wires (IIRC)
*Red = Power
*Black = Ground
*White = Another output or input???
*Blue = Likely datalog output???
Can anyone confirm white&blue?
Where have people tapped to for the Red+black wires?
Also where is a good point to feed the wire through the chasis down to the wideband sensor?
I have a tracysports manifold that already has a bung hole for another sensor (which is nice ).
Thanks in advance.
Old 03-02-2010, 01:08 PM
MB
Member
MB's Avatar
Wideband on mine went through the bulkhead. Pics on my link in your other thread.
Power and earth i'd go to the ECU harness. Again, as per my thread.
Old 03-02-2010, 01:11 PM
Kawasakivtec's Avatar
When TTS fitted mine he tapped into an ignition live under the steering column and ran the earth through to the engine bay, same with the wideband, there is a rubber grommit just below the brake servo on the left hand side of the engine bay.
s2konroids's Avatar
Thanks chaps.
Old 03-02-2010, 01:14 PM
s2konroids's Avatar
EDIT.
I know where you mean now, got confused for a moment .
Old 03-02-2010, 01:22 PM
loftust's Avatar
If it's a PITA running several wires through the bulkhead, another good earth point is where bonnet release catch secures to the body.
Old 03-02-2010, 01:47 PM
UK Moderator
chrisr111's Avatar
*Red = Power
*Black = Ground
[media]http://www.youtube.com/watch?v=ivOtfoY8P2Y [/media]
Chris.
Old 03-02-2010, 01:57 PM
E4RTH WORM JIM's Avatar
Nice vid
Old 03-02-2010, 02:03 PM
s2konroids's Avatar
Cheers Chris mate, nice onee
Old 03-02-2010, 02:55 PM
razzele's Avatar
Any questions mate give me a ring. I installed this about a month ago.
Quick Reply: AEM AFR gauge and wideband installation
