4 Wheel Geometry Set Up At Horsham Developments
Not really much you can do on lotus, toe arm is same as s2000 at the rear and ryou can only add shims to reduce camber on a standard car unless you get full camber kit. The design on the lotus is very simple, Is not like s2000 you can have whatever camber, caster and to
Yes we work on a few Lotus as well, we have a s2 Elise with a supercharged k20 at my shop at the moment
Setup on most car is all about the same, it only take few minute to drive around and normally you will understand how the car behave and how to improve it, once you understand the physics then you will just know how to do it.
Just had my decat fitted (cheers Dixon) at H-Dev as they are 2 mins away from me. Jez says he'll do my alignment when I fit my new suspension and is happy to go with any settings I provide and is totally flexible.
He's happy to take on any work for the skip and is keen to get into hondas
I certainly would reccomend them.
TokeMadBowls420
06-08-2004 07:47 PM
