4.77 Gears
Old 02-01-2004, 10:14 AM
  #21
tenblade2001's Avatar
As a yank with the 4.77 gears, I can answer some of the questions.
1) you're acceleration will significantly improve. The lower gearing makes the s2000 feel like a whole new car. I let people take mine for test drives, and I constantly hear "wow!".
2) the car is not any slower at 60mph. In fact, you get to 60mph much faster than the standard s2000 with the 4.1 gear. You will have to shift more, but its a small price to pay.
Old 02-01-2004, 01:16 PM
  #22
xviper's Avatar
Originally posted by Subaru2000
The other problem is, you have to change in 3rd before you get to 60, in a car with standard gears you don't, so is it any slower to 60 due to the extra gear swap?
This will be purely dependent upon your shifting ability. The "gears" WILL help accelerate your car much quicker. Now, the big question is:
Will the advantage of the quicker acceleration be stripped away by the speed at which you shift. If you are a lightning fast shifter, then yes. If you shift slowly, then NO!
Old 02-01-2004, 02:09 PM
  #23
splodger's Avatar
orginally posted by Brian Marshall
I'm assuming you'd do the Yellowbox yourself. It would be cheaper if you removed the diff yourself, and took it to a specialist to change and setup the gears.
What's a Yellowbox? And could a mechanical incompetent really be able to "do it"?
Also, at motorway cruising speeds (85mph) what revs will the car be pulling in 6th and how does that compare with stock diff?
How does this change (to 4.77 diff) affect mpg?
Incidently, when it comes to improving the performance of the S2000, who are the best people to go to in the UK who really know what they are doing when it comes to this engine?
Old 02-01-2004, 02:12 PM
  #24
at 85mph, I am at 5300rpm
Old 02-02-2004, 08:16 AM
  #25
Turtle's Avatar
A Yellowbox is a little electronic box that modifies the speed signal. It just intercepts the speed signals from the gearbox, and adjusts them. You use it to correct the Speedo so it still reads correctly after you've changed the gearing.
-Brian.
Old 02-02-2004, 09:28 AM
  #26
Banned
Subaru2000's Avatar
[QUOTE]Originally posted by xviper
Old 02-02-2004, 09:58 AM
  #27
xviper's Avatar
Originally posted by Subaru2000 Ever timed it Xviper?
No, it wouldn't be that accurate anyway. I'd need something that could accurately time between 1/4 and 1/2 second. This is what I estimate it takes me to do a fast shift. As seen in ItalianBuckwheat's thread, with 4.44's, he shaved off about .3 - .5 seconds 0-60. With 4.77's, you will need an extra shift. If it takes you 1/2 second to do one shift, then you might break even. If you can do the shift in less than 1/2 second, you might be ahead. However, if you are only talking about maxing out 2nd gear, you'll be faster to that road speed with 4.77's than with 4.44's. Once the 4.77 car shifts, the 4.44 will gain a bit until he has to shift. But we're talking fractions of a second here.
JPRICE!
01-23-2011 03:22 PM
RayRay
03-18-2009 08:19 AM
REV_29K
16
03-03-2005 06:38 PM
JoeD
07-31-2002 09:11 AM
rocketman
03-09-2001 02:46 PM
Quick Reply: 4.77 Gears
