4.57 gears - real life performance improvement?
#93
After getting the gears installed - Are you guys installing the diffs yourselves?
How will you know if the gears have been set up correctly without actually installing the diff and going for a drive?
#95
(if I ever get the bits and get it all put together )
#96
I'm fitting my diff with my much more mechanically skilled Dad. I've just phoned the local mechanic who is fitting the final drive into my spare diff - ansaphone says he's away (presumably on holiday) until Tuesday next week.
AB - the 4.77 looks a bit too high a ratio? Have you seen your top speeds in each gear?
#97
4.625 final drive installed in the diff Here's a warning - my mechanic had to fanny about with the diff because the spacers supplied (three alternatives) weren't big enough - he would have preferred to have started with the biggest spacer you can buy (3.455mm - part number 41387-PCZ-003) and ground down a few thousandths of an inch if required - ihis is precisely the approach he is taking with PJL's diff over the next few days.
#98
Originally Posted by Turtle,Jun 22 2005, 09:57 AM
If you think how the acceleration feels in 3rd compared to 4th with standard gearing, then post change 4th feels more like the old third - happy to scream.
#100
Originally Posted by Paper Lawyer,Sep 11 2005, 07:45 PM
statement verified today Taking it easy as only 120 miles on the new final gear (and there's a slight noise akin to a rubbing brake pad which I can hear if I switch off the stereo - hopefully this should reduce as the gear wears in) but I dropped down to 4th (rather than 3rd) when coming out of a 50 mph limit on the motorway - pulled like third
-Brian.
