215/45/R17 87W
87 stands for a load rating of 545kg and W for speeds up to 168mph.
As long as you go for these ratings or higher you should be covered legally, if not, in an accident insurance and police could take a dim view.
You could use a Z rated tyre suitably rated.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
W is speed rating, not load rating.
87 Load rating is 545kg per tyre.
92 Load rating is 615kg per tyre.
As I see it, they make tyres for many cars, most cars are heavier than the s2000 so the load rating is far higher than needed, thus 87 will be fine I would have thought. Someone will need to clarify I'm not talking crap though
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
Having a higher load rating also results in a stiffer tyre wall, hence the Goodyear GSD3 XLs are recommended for the front of the S, as they get somewhere near the stiffness of the RE050MZ.
