18" Wheels - Speedo recalibration?
A question for those who have changed their wheels:
Presumably this makes your speedo under-read more than usual. Have any of you had your speedo recalibrated, and if so, is it a simple job for any Honda dealer?
I'm going to get mine recalibrated if my 18" wheels ever arrive. I have had a quick look on the net and there are plenty of people who'll come out and see you or you can visit them.
Mike
Mike
Hi Alex,
You could check your speedo with a GPS device like Road Angel or Road Pilot.
Rick's Signature Accessories do a little device that allows you to recalibrate your speedo if its out.
http://www.ricks2k.com/products/yellowbox.php
Cheers,
Cheers,
IMHO The setup of the S2 is so precise I wouldn't want to change the rolling radius.
I went from
205/55/16 to 225/40/18 on the front
245/45/16 to 245/35/18 on the rear (NB 245/45 is the real size of the rear S02s )
If you use this calculator http://www.tyresave.co.uk/tyresize.html you will see that the diameter only changes by 5mm on the front and 2mm on the rear. Not enough to make a significant difference. (you change by that much with tyre wear anyway )
Chris.
I went from
Chris.
