09 Cars
#31
14,000 miles no problems or complaints so far, touch wood!
26 - 28 mpg on Shell V power .
never uses any oil, due 2nd service due next month.
warranty until May 12 and I shall then extend it for 3 years, worth the cost.
needs a new screen, to be fitted by autoglass tomorrow
rear tyres at 3mm so they need replacing in a couple weeks.
#32
Never uses oil and since sorting out the geo and replacing the rear tyres a couple of weeks ago, drives like a dream.
But will be extending the warranty just in case, so suggest you do the same.
#34
UK Moderator
Wait until the 3 year warranty is up, then buy an extended one. Your dealer will almost certainly send you an application form when the time is near.
Don't pay more than £300 per year for it.
#36
UK Moderator
Bokkie's situation is ongoing, and redress is being discussed with Honda.
The engine issue that affected a small number of MY09 cars has been identified and can be easily cured under warranty.
#37
So I'm guessing big end bearings,shells or crankshaft thrust washers
Bristol Honda are on the ball with the issues, sadly many other dealers aren't
#39
The service manager Ian was very helpful and made a very refreshing change to the Honda dealers in this part of the country
Some cars have had a bootom end rebuild, others have had parts changed
My money is on thrust washers and crank walk
I am taking some spare batteries for my dealers hearing aid tomorrow although my issue may be unrelated
